55 F100 cowl vent install
- flyboy71
Re: 55 F100 cowl vent install
Yeah its over by about 1/2" or so but I may just sweep its curve into the cowl and section the hood to the same contour. The front curve will never match exactly but its pretty close. Im just happy I got it where its at. I used various templates to section and try things and this worked out pretty darn good.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
- flyboy71
Well I finally got the vent assembly about 90% installed and closed the remaining vents. All I need to do now is trim the lower front edge and Im all set.
The hinge arms extend into the cab a bit and I might have to make an adjustment to the wiper motor assembly to clear them but it doesnt look too bad.
-Jeff
- Caseys71
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Looking real good. How hard we strive for the end result.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fbomb100
I forgot about this topic . thats looking good there . Now you got me doing some thinking on that one
- marvin2
Found this thread doing a google search for something else. Does anyone know how this turned out, looked like a really cool idea.
- flyboy71
I actually abandoned it. It turned out that the suck factor was pretty high.
-Jeff
- flyboy2610
As in looks, operation, or difficulty of installation?flyboy71 wrote:I actually abandoned it. It turned out that the suck factor was pretty high.
- flyboy71
All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
-Jeff
Hello, do you still have the vent assembly??flyboy71 wrote:All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
