55 F100 cowl vent install
- flyboy71
Re: 55 F100 cowl vent install
Yeah its over by about 1/2" or so but I may just sweep its curve into the cowl and section the hood to the same contour. The front curve will never match exactly but its pretty close. Im just happy I got it where its at. I used various templates to section and try things and this worked out pretty darn good.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
- flyboy71
Well I finally got the vent assembly about 90% installed and closed the remaining vents. All I need to do now is trim the lower front edge and Im all set. The hinge arms extend into the cab a bit and I might have to make an adjustment to the wiper motor assembly to clear them but it doesnt look too bad.
-Jeff
- Caseys71
, Looks pretty good! I'm also liking the louver delete you did on the cowl. Can't wait to see how good it looks when you finish trimming it in.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Looking real good. How hard we strive for the end result.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fbomb100
I forgot about this topic . thats looking good there . Now you got me doing some thinking on that one
- marvin2
Found this thread doing a google search for something else. Does anyone know how this turned out, looked like a really cool idea.
- flyboy71
I actually abandoned it. It turned out that the suck factor was pretty high.
-Jeff
- flyboy2610
As in looks, operation, or difficulty of installation?flyboy71 wrote:I actually abandoned it. It turned out that the suck factor was pretty high.
- flyboy71
All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
-Jeff
Hello, do you still have the vent assembly??flyboy71 wrote:All of the above. It didn't match the curve of the cowl. There are probably better ways to make a cowl door. My plan was to make it motor operated. I still have to vent assembly if anyone wants to give it a try.
