1972 Dana 70 "speedy sleave" part number?
UnMark
Post by UnMark »
Looking for the correct part number for a "speedy sleave" for the rear axel(Dana 70), 1972. Also looking for vendors for this part. I understand that there may be 2 part numbers.
I want to have the sleaves in hand before I tear the thing apart again so that the truck is not down for extended shipping/parts search. This is why I do not currently have a measurement.
What is the best seal number to match or can I use a stock seal number from Napa?
Anyone had experience with this on their 70?
Thanks in advance.
Fraser
Re: 1972 Dana 70 "speedy sleave" part number?
Post by Fraser »
You may find new, upgraded two part seals which incorporate a built in race, so no contact with the spindle. I don't know what they are called, but that's what I used in a 61 Eaton 2 1/2 ton, and that is what a Sterling uses. Look at all the pictures at Rock and see what they offer.
F. Noble, Saskatchewan.
UnMark
Post by UnMark »
Thanks. I am also trying to find a good crossable part number for the lock/tab washer that goes between the 2 spindle nuts if anyone has that.
Jbarnes79
Post by Jbarnes79 »
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
