headlight adjustment
anyone else but me have trouble adjusting your headlights? new adjustment screws work fine but as i turn the screw, the tab on the bucket just bends without moving. i have to pull the bucket with my hands to move it. that spring in there is really tight. its only 53 years old! thanks
- beejaytx225
Re: headlight adjustment
Just in the last few weeks I have experienced this with the tab bending before the light looks like it's level. The adjuster was almost bottomed out by the time they appeared to be where they should be. I got the LMC adjusters and they fit pretty good into the grill. I reused the original spring. I'm kinda hoping they are pretty close to where they should be. I haven't had a chance to shine the headlights on the garage door to see their level. But I feel it will be pretty close
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Family nicknamed her "Bethany"
Central Texas
360 w/C6
Peacock Blue
Central Texas
- beejaytx225
By the way, the new headlight bezel I bought from you looks great on my truck, thank you
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
you bet. glad you could use it. wished i would have had the other one.
if i run across one, will let you know.
