Is it hard to change the C4 auto trans. seal?
jzjames
Post by jzjames »
-where its leaking and dripping? Probably the front seal?
The Bandit
Re: Is it hard to change the C4 auto trans. seal?
Post by The Bandit »
The C4 has been known to leak from the front seal however the o-ring and the seal for the linkage is another place that the C4 is well known for leaking and those are time consuming and require a little knowledge to replace them.
mmerlinn
Post by mmerlinn »
It is quite easy to change the front seal on any automatic transmission ONCE THE TRANSMISSION IS REMOVED FROM THE VEHICLE.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
