'72 F100 Taillight Wiring Harness
Looking for complete taillight wiring harness, engine bay back, for a 1972 F100 Longbed
Re: '72 F100 Taillight Wiring Harness
Hopefully someone here has the wiring harnesses that you need, if not here is a link to NPD that carries reproduction harnesses for the 1972, they are on the pricey side, but good luck finding a good taillight wiring harness as all the ones I have seen in junk yards, and my own have been hacked up by previous owners. I also added a couple other places you might want to look at for your search. At the bottom of the links is one for introducing yourself to the group.
https://www.npdlink.com/product/wire-as ... 7824/50696 (tailight wiring harness)
The next one you will have to look up on NPD Ford Truck website:
WIRE ASSY, Body, runs along frame, repro, D0TZ-14405-E (body frame wiring harness - note this is for a Camper Special, you maybe able to modify?)
http://www.car-part.com (junkyard search all over the country)
https://www.facebook.com/groups/1441048622792281/ (Fordification Facebook Parts Wanted)
http://www.fordification.com/forum/viewforum.php?f=1 (Welcome Mat)
Let us know what you find!
Regards
Regards
Thank you 390FE1972 for the suggestions
Check with Narragansett Reproduction in RI they can make you one.
