Expansion valve for factory ac 240 69 bump
Need the expansion valve as far as I know it's the last thing I need for the AC to work. I just need one that'll work in the mean time while j get the funds together to replace the entire ac with modern components.
Re: Expansion valve for factory ac 240 69 bump
"Scuzzy_1250"]Need the expansion valve as far as I know it's the last thing I need for the AC to work. I just need one that'll work in the mean time while j get the funds together to replace the entire ac with modern components.
From a lifetime retired HVAC tech believe me this is one part you do not want to throw a used part into expecting it to work. The diaphragm's in them wear out from cycling, (as well as the spring behind the diaphragm).
NPD has new ones:
https://www.npdlink.com/product/expansi ... 0569/50801
