side/toolbox rattles badly
dougself
Post by dougself »
so the door on the sidebox has an adjustment, but if I set it back so it does not rattle it does not sit flush with the body. did these things have little rubber baby bumpers to prevent the rattle? I have tried every adjustment to make it not rattle.. thinking of heating up the latch and bending it a little. thoughts ?
Busboy
Re: side/toolbox rattles badly
Post by Busboy »
Maybe some glue on foam gasket material?
1967 F-100 4x4 custom cab.
Mach428
Post by Mach428 »
They had a gasket glued to the door that sealed the compartment and prevented rattles. Good luck finding the gasket as I've been searching for one for 25 years
Mach428 wrote:They had a gasket glued to the door that sealed the compartment and prevented rattles. Good luck finding the gasket as I've been searching for one for 25 years
Any idea what size/type the gasket was originally?
Mach428
Post by Mach428 »
The size would be the same as the inner lip of the toolbox. It looked like a trunk weatherstrip
This place has about anything you care to try. https://www.steelerubber.com/universal-parts
Mach428
Post by Mach428 »
Wow, excellent. Thank you!!
The 83-0131-73 part number looks very close to the original although the original was glued with adhesive. I'm going to order this and try
