Parting Out 1972 F100 Parts Truck
Have most of a 1972 F100 LWB that we've had sitting in the back yard as a parts truck for the past two years. Looks to have either a 360 or 390 with a C6. Rear end is a Ford 9" with 3.00 gears and 31 spline axles. Has a almost my completely intact grill and both headlight buckets. Radiator support is solid. Most of the front clip is there and solid. Looks to be one of the fancier trim packages, maybe Ranger, and the majority of the cab trim is there. Hood trim is intact. Bed is gone, steering column is gone. Situated just north of Shelby, NC. Not able to ship anything at this time. We just pulled it up beside the garage today so I'll get some pictures tomorrow when it's daylight.
Edit: Is actually 131" wheelbase, not SWB.
- calipilot227
Re: Parting Out 1972 F100 Parts Truck
If you're willing to ship, I'd like to buy the AC unit
My Ford: 1970 F250 Camper Special (360, C6, 2WD, drums all around)
My Daily: 1998 Volvo S70 T5
"In the beginning, God made the light.
Shortly thereafter, God made three big mistakes.
The first mistake was called "Man." The second mistake was called "Wo-man."
And the third mistake was the invention of the poodle."
Does the radio work? How much if you would ship.. Need radio trim plate knobs.. everything. plug?
How about the ash tray and the retaining mechanism for it? Shipping to 95687.
1971 F-250, Wimbeldon White, 360, PB, dealer add-on A/C (A.R.A. brand), 1970 coded interior (23 - Med. blue/Light blue) with 42,000 miles.
- magic bus
Id like to have that piece of moulding on the lower part of the door on the driver side. I'll take that gas cap too.
71 F100 2WD Longbed Sport Custom 390 C6
67 Econoline E100 200 I6 3 on the Tree
70 Mustang Coupe 302 C4
97 Expedition 4x4 Eddie Bauer
Sorry I haven't gotten back to anyone, I've been busy with elbow surgery and bone issues in my feet, so getting around has been a chore.
I'll be going out later when it's cooled off some to pull the radio out and test if it works. Granddad says $75+ shipping for it and all its bits if it works. Should be able to fit in a decently small box even when all bubblewrapped and shouldn't be any more than $20.05 via USPS depending on weight.jlb wrote:Does the radio work? How much if you would ship.. Need radio trim plate knobs.. everything. plug?
Will pull it when I get out this evening. Everything's there,a bit rough moving through the slide, can probably WD40 it back to working order. Granddad says $30 + shipping, which should be no more than $20.05 depending on packaged weight.mulletmobile wrote:How about the ash tray and the retaining mechanism for it? Shipping to 95687.
I'll check the cap to make sure the inside's not all rotten, probably no more than a few bucks. Molding might be hit or miss, the previous owner used screws to hold several other pieces of it to the truck when the original clips failed, so I'll see how it's held on tonite. Shipping it might be an issue as we don't have anything to ship it in currently.magic bus wrote:Id like to have that piece of moulding on the lower part of the door on the driver side. I'll take that gas cap too.
There's actually already plans for it, and shipping it would be a pain as well as costly.calipilot227 wrote:If you're willing to ship, I'd like to buy the AC unit
- magic bus
Thank you for checking on that.
Id also be interested in the ignition switch bezel that holds the switch to the dash if you still have it. Im in no hurry. If that moulding is ok Id be fine waiting till whenever you could find a box.
Thanks again.
Thanks again.
- magic bus
Im also interested in your grill inserts if your willing to ship
I am looking for a inner fender support for the LEFT side if their different
Living the Dreamhttp://www.fordification.com/forum/ucp.php?i=u ... =signature#
In need of a factory 2 barrel carb if you have one on it for sale. Let me know cost/shipping.
Hello, I'd like to buy the complete radio set if it's still available.
John
John
1972 F100 custom. 360/c6/PS/long bed Idaho truck with 75k
I would like to buy the Cab minus the doors if you are still parting this truck out
Very interested in the grille and headlight trim if you are willing to ship to the UK?
Do you have a set of '68 - '72 interior door panels?
(Like the one in this picture except without the holes circled in blue.)
If so how much for 2 shipped to 39443?
