I need either a single or a two groove four bolt hole water pump pulley to fit my SBF engine. The diameter can't be more than 5 & 7/8" outside diameter and I need a pulley groove to be 1 & 1/2" to 1 & 5/8" from the flat where it bolts to the water pump.
Here's a few of the part numbers I can use:
C90Z-8509-C
C0DE-8509-A
C6OE-8509-B
C5AZ-8509-D
C5AE-8509-A
Thanks in advance.
edit for part number insertion
Found: A two groove water pump pulley for a SBF engine
Last edited by basketcase0302 on Mon Nov 19, 2012 5:43 am, edited 1 time in total.
- Alstoyz
Re: Wanted a two groove water pump pulley for a SBF engine
I've got a dual groove pulley, it's 5-1/8" dia, 1-1/2" from the flat to the outer edge of the first groove. The casting number is D8BE-8509-E7A.?.?
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
1972 F-100 SWB 4X4
Re: Found: A two groove water pump pulley for a SBF engine
I found it late last night, thank you for replying. I believe I had yours saved in my favorites, (if you have it listed on ebay). Was about to hit the buy it now except needed the one measurement. It's a unique pulley for sure-I bet someone else buys it as there were only a handful on ebay.Alstoyz on Sun Nov 18, 2012 11:02 pm
