What products do you guys like to use wen threading a hole or bolt?
I have had good luck with Tap Magic.
Taping fluid
- OldRedFord
Taping fluid
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- Heathcliff68f100
Re: Taping fluid
i like WD40, or 15w40 motor oil, assybly lube, and if things are tight, or i have some around, type F tranny fluid
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
- ximy
Re: Taping fluid
I've used TM pro-tap... working with aluminum it is a must to have a good tap fluid
1967 f250 428
- eggman918
Re: Taping fluid
Tap Magic is good all around fluid.OldRedFord wrote:What products do you guys like to use wen threading a hole or bolt?
Rapid-tap is also good
Dark cutting oil with about 30% moly assy. lube is good in hard steels and stainless steels,you want the green stinky assy.lube it has the most molly in it.
go-jo hand cleaner is the best in cast iron.
The key is the physical property's of the material and tool,then pick the fluid.
also when tapping 1/2 turn in 3/4 turn back ,in a blind hole pull tap out and clean it and blow out hole often .Also always use the smallest tap handle you can
that way you will be less likely to break tap
Steve
- ForingaMex
Re: Taping fluid
Good ol' Lard. Where I grew up everybody used it and even some guys around here do. In the little experience I have with tapping, I've used it and it works good. Never tried anything elso though.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
Re: Taping fluid
i dont do much tapping. but i usually just use whatever oil i have laying around .
- averagef250
Re: Taping fluid
Like steve said you gotta pick your lube based on the material. Cast iron is different from everything else. I use diesel fuel in cast with great results. For tapping in my machines it's the soluable oil they have in thier sumps.
