Neep help identifying this part
- 68F250
re: Neep help identifying this part
Horn relay (beep beep).
Barry
- jor
It looks like the horn relay.
jor
jor
- customcrewcab
i think thats the flux capacitor, when its working right you'll travel back in time, just make sure you have plenty of plutonium.
when you get that working, I need one metal 69 grille and two chrome ones. If you can lay a hand on one, a standard cluster. maybe a 72 am/fm radio too
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
- boots
Re: re: Neep help identifying this part
customcrewcab wrote:i think thats the flux capacitor, when its working right you'll travel back in time, just make sure you have plenty of plutonium.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- customcrewcab
