Creating a Sleeper!!
71Ford
Post by 71Ford »
I'd like to possibly install a hotter motor....maybe a 390 or 428. But I want to keep it looking stock.....little skinny white wall tires, and quiet exhaust. My current exhaust system is, I'm guessing the factory setup...it is the quietest exhaust I've ever heard...very luxury car like. I'd like to keep the quietness but would like to know how exhaust cut outs work/perform. In a perfect world I could drive around sounding/looking docile, but with a push of a button, trip the cut out option and melt the street w/ header fire and tires.....
How do cut outs work? Am I being unrealistic? It sounds like fun.
w/370 horse power what kind of 1/4 mile times and 0 to 60 times are possible?
Shawn :D
http://www.fordification.com/galleries/ ... p?pos=-851
71 XLT RANGER ->203,000+MILES/NOT REBUILT
99 GMC 4x4 Suburban, 94 Saturn 200k, 03 Chev Venture
crazy larry
re: Creating a Sleeper!!
Post by crazy larry »
exhaust cut outs are cool until they rust shut. you do have to open and grease them often to keep them from rusting up.. .... i knew a guy who had the mr gasket cable controlled jobs, they worked well :drive: .
as far as hp to et , your gonna have to go more than hp to get the et. your going to have to set up the gearing, and think about traction..... i can't get any with a stock set up, and my rear is killing me. i ought to be running at least a low fifteen. but with all motor and no hook up, i ain't going any where quick. and i'm not saying i have that much motor. but i am saying i can't get what i've got to hook up.
what tranny are you running?
what rear gear?
:hmm:
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
Heavenlyfire
Post by Heavenlyfire »
See if you can get your hands on a 460, I love it and have made a lot of hot rodders go :hmm: . :lol: Good luck to ya just make sure to beef up the drivetrain as you go too, or else you won't go.
Faithful Old Road Dog
Post by Faithful Old Road Dog »
I've seen the bypass pipes at swap meets. Basically it's a 'Y" pipe that gets welded inline with your existing pipes before the mufflers. There's a bronze "gate" that's cable operated. When you need to run straight pipes, you pull the cable that's mounted inside your vehicle and that opens the "gate" which bypasses your muffler.
I've also seen the bypass that has a cover that you unbolt. But that really wouldn't apply for a sleeper, just your occasional visit to the track.
As far as your 1/4 mile times with 370 hp, you would still need to factor in rear end gearing, tire size (width and diameter), type of tires, other stuff like ladder bars, traction bars, leaf springs, weight transfer, line lock, convertor stall (if auto tranny), etc. Not to mention reaction time of driver.
67F250CS
Post by 67F250CS »
Speed is directly related to investment $$$ :lol:
1967 F250 Camper Special
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
You can also get electric solenoids hooked up to the cut-outs, so there isn't a cable (or two) to have to pull. Once flick of a switch and they open up.
One thing to consider (or at least research) is the air/fuel mixture. I'm betting that if your truck is that quiet, it's got a fairly restrictive muffler on it. Your carburetor is probably adjusted for that. Running without that restriction is going to lean out your mixture, which obviously isn't the best for performance. I seem to recall a setup where you can manually adjust the mixture from inside the vehicle, which would be the perfect way to compensate for that lean condition.
ttyR2
Post by ttyR2 »
Or, go retro and put lake pipes on it.
Jeremy
Heavenlyfire
:2cents: By the Way, did I mention 460 :hmm: . Oh ya I think I did :woohoo:
morganater
Re: re: Creating a Sleeper!!
Post by morganater »
Heavenlyfire wrote::2cents: By the Way, did I mention 460 :hmm: . Oh ya I think I did :woohoo:
:stupid: :yt: :stupid:
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
greasemonkey060
Post by greasemonkey060 »
i thought about doin' the same thing.. maybe after a rebuild this summer, i might hop it up a bit..
as for pipes, im running straight pipes, its bark is worse than its bite.
good luck!
-brandon
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
1968flareside
Post by 1968flareside »
:lolprev:
I hear ya man!
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
:fte: and :fr: DON'T FORGET!!
cobraF100
Post by cobraF100 »
71Ford,
Off Topic BUT are you coming to the " Texas/Oklahoma meet and greet " ?
http://fordification.com/forum/viewtopi ... sc&start=0
We are having it at Rusk DragWay..Hope to see you there !
Chris
Never Forget Our Soldiers
willowbilly3
Post by willowbilly3 »
Put the engine in the back. Well seriously move as much stuff aft of the rear axle as you can, like the fuel tank and the battery. You might also put some weight back there but that could prove counterproductive. Every 100 pounds is a tenth of a second. Aluminum wheels and skinney tires upfront, fiberglass bumper, aluminum intake.
