hey guys!! is it hard to take out a c-6 tranny
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
i cant get a loan, so when u aint got the money. theres pick and pull. i never taken out a tranny. is it hard and is it something i can do... im a virgin when it comes to things like this. pick and pull get some good stuff. i heard there are many different linkages on a c-6 thanks fo info ???
THANKS
Mugwump
Post by Mugwump »
Why are you taking it out? What's your plan?
Taking it out is the easy part.
'65 F100 Custom Cab Shortbed - current project
'69 F250 Ranger CS (Tug) - P/S, P/B, AC - 390/C6/D60 - Reef Aqua/Wimbledon White [sold]
'66 F100 Custom Cab (Shep) - 352/4sp/9" - Wimbledon White [gave to OldDawg]
67mann
re: hey guys!! is it hard to take out a c-6 tranny
Post by 67mann »
Bolts come out---Bolts go in
tranny
Mugwump wrote:Why are you taking it out? What's your plan?
tranny is fried. hoping to find a nice one at pick n pull. everyone says they can fix it, but they all say 1200 cash. theres no money in repairing it .,oh a 69 f250 ranger with a 390... im gonna have to find someone from craigslist
hopefully not a methhead or budweiser auto tech school graduate.
THANKS
kaptnkaos
Post by kaptnkaos »
Hey LUVMY69FORD250RANGER
You have to disconnect the drive line, linkages and speedo cable.
Remove the inspection plate.
Remove the torque converter/flex plate bolts
Remove the bellhousing bolts.
Remove tranny mount bolts.
I can't remember if you have to remove the tranny cross member to get it out or not, it seem like you do
Just don't be under it, cause it can mash you like a tater if you don't have a tranny jack...
You'll probably have to jack up the body and block it up to get the tranny out from underneath the rig...
I might have missed a thing or two... I don't remember
KaptnKA 8) S
basketcase0302
Post by basketcase0302 »
luvmy69,
Aint' too bad, but like the Kapn' said be careful.
Much easier with another set of hands for the "wiggle and fall" part.
Basketcase
QC
Post by QC »
A transmission jack makes it A LOT easier. A C6 is heavy if you are laying on your back.
69 F-100 Ranger 302
customcrewcab
Post by customcrewcab »
1200 :eek: saw an add for a built upgrade street strip one for 600 i think. i'll look for it. :thup:
binder56jd
Post by binder56jd »
depends on if your tranny is post or pre op
now serving #235
Re: re: hey guys!! is it hard to take out a c-6 tranny
kaptnkaos wrote:Hey LUVMY69FORD250RANGER
You do, both the transmission and front suspension crossmembers, the bellhousing on an FE C-6 will not clear the suspension cross member.
I certainly wouldn't try it by myself in a Pull A Part without a transmission jack.
:2cents:
ford4x4fun
Post by ford4x4fun »
I pulled one out of a F350 69 to be exact, if your at a pick a part place, you can have it out in 20 minutes with the right tools. I was in a pinch and needed a tranny, lefty loose on all the bolts, cut the drive shaft off, and hooked to it with a 4 wheeler. Came right out landed in the dirt, and that is what is in my truck today. Of course that was a pick and pull, I didn't have any worries with being nice to the rest of the truck. Just there for the part.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
kilog55
Post by kilog55 »
guess it depends on where she (he) wants to go and......
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
oldschoolrods
Post by oldschoolrods »
The cross member has to come out, if memory serves me right, theres like a 9/16 head bolt that goes under the cross member on the mount that you can take out then jack the trans up as high as it will go and it should lift the mount right off and then you can unbolt the cross member, don't be afraid to hit it to get it out. Other than was mentioned, there might be a couple transmission cooler lines that need taken off.
Here are a few tips to try and make the job easier for you.
I'd really recommend renting a transmission jack, will make the job safer and easier. If the transmission doesn't sit real well on the jack, you can use wood to make it more stable.
Be sure to block the wheels and set the emergency brake before you take the drive shaft out. (Once the drive shaft is out theres nothing really holding the truck in park)
Make sure you support the engine with something when you take it out, preferably some boards or something solid, that way the engine will be close to where its supposed to when going back in, a bottle jack will work but will sink and make things aggravating.
It's just as important to keep the transmission straight coming out as it is going back in.
When you have everything disconnected and are ready to pull the transmission, it might be stuck on the dowel pins, I take a screw driver and a hammer and drive it in at points around the bell housing til I can get a pry bar in to separate it from the engine.
Hope that helps, if you need any more help just post back.
On edit: I just noticed there is a C6 for sale in the parts for sale forum
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
rjewkes
Post by rjewkes »
I beleive the tranny shops drop the trans cross and the cross just behind the engine too and also use a tranny jack.
been told fully drained they weigh about 100 or so pounds. Heard stories of people dropping them and juist rolling over and out from under the truck but that still sounds dangerous.
fuelly.com
ford4x4fun
It is pretty dangerous, but he is going to a pick and pull place, I am sure the truck is going to be in the dirt, like the one I pulled the Tran from. No place for a transmission jack and such. Now when you do your truck all this advice is top notch. Take your time, and do it safe :2cents:
US ARMY Retired
