Official CNC milled aluminum parts for sale listing
Private parties only. No eBay/Craigslist listings.
Ranchero50
Post by Ranchero50 »
Edited 1/5/2018: Parsed any of the old sale request posts and tried to get the images showing again. Been making these for almost 10 years now. Prices as of 2018 are:
Dome lamp bezel and lens $40
Ash tray pull, $20
Shipping is $3 for the lens, $5 for the pair. Canada $6, and $10.
Payment through USPS money order or Paypal
For all sales, PM me first.
Thanks,
Jamie
For the CD bezel and visor clip. They weren't viable. For the sun visor clip, buy the chrome plastic one for the dent sides. The CD bezel was just too complicated and would have been a couple hundred bucks once finished. Sorry.
Decided to put the parts for sale in the parts for sale section with links to the original threads.
Dome lamp bezel kit; (for sale, $40)
http://www.fordification.com/forum/view ... hp?t=25709
Ash tray handle; (for sale, $20)
http://www.fordification.com/forum/view ... hp?t=32865
4 speed floor shifter bezel; (in process)
http://www.fordification.com/forum/view ... hp?t=28105
DIN sized CD mount that looks stock and fits in the stock hole.
Ball Milled instrument cluster plate for aftermarket gauges.
If interested, please PM me, prices include shipping.
I'd like to keep this thread as a sticky with updated info as the parts come out, are made, sold and shipped.
Thanks,
Jamie
Ranchero50
Some very basic rendering of the CD bezel since I'm finally figuring out how to use BobCAD... I'll have to do two detailed drawings to build the cut profiles off of, one of each side. The mounting holes and tabs aren't here yet.
And the four speed bezel with abasic render.
Jamie
Ranchero50
Re: Official CNC milled aluminum parts for sale listing
The Sun Visor Clips are in limited production form... I need some help making sure they fit correctly.
http://www.fordification.com/forum/view ... =6&t=36684
Jamie
1971ford
Post by 1971ford »
Tomorrow ill get pics of it on the truck.
Ranchero im sending you the rest of the pics. i dont want to make this thread slower to load for the dial-uppers.
Another super duper part!
Click on this picture so it doesnt have the rinkles from the forum's resizing. i must not of resized it all the way to 25%.
Flawless finish
-Ryan
Ranchero50
Teasers...
Did this in about an hour after a virgin install just to figure out how to do it.
CD bezel model. Still tinkering with it
I still need to figure out how to do the NC side, then post it to the machine.
Such fun,
Jamie
Ranchero50
Silly, I don't know how the process would go with chips. From what I understand they tend to vaporize vs. melt clean on a forge. The chips are only around .004-.006" thick. One other concideration is holding a rough cast bezel and the steps to get it trued so it'll go into a fixture for final machining. I like the idea of reusing them but I don't think it'll work from what I've read and heard.
Here's a couple screen captures showing some of the fun of dealing with solids in OneCNC. One method is to build a wireframe drawing by hand or what I did was create 'extrusions' from drawing the end views. Took some time and lots of figuring but I bought this program to make these parts.
This is the body less the front cutout. There are two body extrusions and four cutter extrusions.
This is the cutter to trim the inside of the CD bezel out. A pretty simple extrusion but of course I had to go back in to add the radius on the end caps and then make sure the part was watertight once it was merged together (it wasn't the first time so it just cut the planes out, not the whole solid)
Finally once the cutter was watertight it cut the face out. I had to redo things several times just to get the internal radius' so I can cut this with a .250" ball mill.
Now I get to play with the CAM side to see what cutter strategies I can use to whittle out some wood tomorrow after cleaning out the mill.
Jamie
Bump, are you still making parts sir? Can you post new pics of said parts?
cdnwillyg
Post by cdnwillyg »
Just to let everyone know that Jamie's parts are awesome, great quality and PRETTY! :clap: :clap:
Thanks again Jamie
Stony Plain, Alberta, Canada
:drive:Willy
Ranchero50
hfdco4 wrote:Bump, are you still making parts sir? Can you post new pics of said parts?
Back up (I hope). Let me know if you can't see them...
MikeB
Post by MikeB »
Just wanted to say to y’all. I Received the dome light and it’s 100 times better than OEM or Aftermarket plastic junk. Paying $20-30 bucks for after market that will peel and brown up in a few years is a waste of money. Plus it just looks the way Ford should have done it.
Thanks Jamie.
1972 F250 4x4 XLT stock but P.O. hacked
2010 F350 CC LB 4x4 stock
basketcase0302
Post by basketcase0302 »
Bump,
I sent a guy this way from another page Jamie.
Never knew you'd produced the visor brackets either. :thup:
greenmeanie48
Post by greenmeanie48 »
Jamie, haven't visited this sight for several years , bought one of your dome light covers for my 72 f100 ,I know it's wrapped and buried somewhere but can't lay my hands on it ,was wondering what else you are now making besides that and ash tray pull , thank you , Dennis
Ranchero50
greenmeanie48 wrote:Jamie, haven't visited this sight for several years , bought one of your dome light covers for my 72 f100 ,I know it's wrapped and buried somewhere but can't lay my hands on it ,was wondering what else you are now making besides that and ash tray pull , thank you , Dennis
Honestly, nothing. I haven't been real active with selling stuff as I'm building a model A speedster. If anyone wants to polish their own, I'll sell them but I'm out of the polishing business for a while.
Thanks,
Jamie
greenmeanie48
So what would be the price of the pieces you have that aren't polished ? And is the lens out of dome light till after polishing ? I'm in Dundalk Md ,21222, thanks. Dennis
Ranchero50
Knock five bucks off of each part. If still interested send me a PM and I'll send you the payment details.
Pics of the dang project for S+G's :D
