Dump bed?
- mustango
Dump bed?
Anyone know of a dump conversion I could install on my '71 f100 l/b? I'd like to be able to dump a yard of gravel instead of shoveling it out. Also it'd look trick on a semi custom pickup.
Mark C.
'71 F-100 LB, FE 390.
I was thinking of the immortal words of Socrates who once said, "I drank what?" (Val Kilmer in Real Genius)
- 460 crew
re: Dump bed?
I remember seeing a roll up mat thing that was on tv, dunno if it was any good but might be worth lookin for rather than changing over your bed. I remember you could take it in and out.
re: Dump bed?
There's an auction on E-bay for that roll-out style:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33655
At $75 it might be the ticket if you only need to do something like this once in a while, but probably not for a commercial vehicle, where it's a regular thing.
- hardtailjohn
re: Dump bed?
Try www.surpluscenter.com they advertise the whole thing in their catalog... I always thought one of those would be handy too!!
John H.
John H.
- 72hiboy4x4
re: Dump bed?
try this link....
http://www.motherearthnews.com/library/ ... Dump_Truck
its an interesting idea for little bucks.
- mustango
re: Dump bed?
Pretty cool idea, but nI'd be more interested in the hydraulic type for my truck. It's going to be hot rod/utility vehicle.
Mark C.
- FoMoCo
re: Dump bed?
Instead of hydralics thers a kit for using an air bag. I saw it on the Trucks TV show. It will utilize the existing bed and frame and be able to tilt the bed about 60 degrees of level.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- 72hiboy4x4
re: Dump bed?
one other thing to consider is that, being a 1/2 ton truck, how much quantity and how many times is that truck going to haul a yard of gravel before the suspension, rear axle, steering, bearings, ect. give out? If it is occasional use, than probable a long time, but for serious use, a 3/4 ton might be a better choice.
thats a lot of effort and cost for just the occasional dumped load.
I have never been impressed by a 1/2 ton trucks load capacity when it comes to the heavy loads, like gravel. My F150 has to use the air bag suspension just for lighter loads i haul! (scrap steel mostly)
that being said, as soon as I get settled into the new house I am working on building my dump trailer! with 3 trucks available, I can match the truck to the load and not worry about 1 truck being down.
the air bag idea is a great one. tow rigs use something similar when uprighting an overturned semi trailer in soft ground.
just my humble
worth
just my humble
- mustango
re: Dump bed?
I'm going to stiffen the springs a bit. But the Main reason I'd like a dump bed is because it would be a cool custom addition. I plan on semi restoring the truck and installing 18" Torque Thrust 2s and lowering it a few inches. It won't be a show truck but it'll look good and still be used on occasion.
Mark C.
re: Dump bed?
Occasional hauling is fine for that 1/2 ton. That stiffer spring will help. Keep in mind the bearings are still the same. Sounds like a cool set up. Why don't you do like those mini-trucks that lift the entire bed up in the air, spin and then "fly apart"?
- mustango
re: Dump bed?
Sure, but only if it'll spin with a yard of gravel in the bed?
Mark C.
