I've found the parts and I'm putting the closed knuckle on my '67 f-250 (dana 44) back together. Does anybody have any torque values for putting these things back together? I would think that the 8 seal retaining bolts, the 4 top and 4 bottom bearing retainer bolts and the 5 backing plate bolts should have some specific torque values. If anybody has done a few of these or has a shop manual laying around, I would appreciate any info you could give me that would make it easier. I'm using a book called the "Ford F-series Owner's Bible" by Moses Ludel. It's a good reference with a lot of pictures, but it doesn't list many torque values because it covers so many years and models. Thanks for the help.
Anybody know the torque values for a closed knuckle?
Moderator: Doug Comer
- averagef250
Most shop manuals have standard torque tables in them. You just look up the size of the bolt and it's grade and it gives you the torque specs.
I work on transmissions and suspension parts everyday and yes, I actually do torque stuff with a calibrated torque wrench! I just use the charts, so much easier than looking up a torque spec buried in a factory manual somewhere.
re: Anybody know the torque values for a closed knuckle?
10-25 ft/lbs
http://www2.dana.com/pdf/5310-3.PDF
Old trucks, like old computers are more fun. Is the web really fun? No but its utilitarian. Spitfire, Wildcat, Fidonet, QWK and door games were FUN. The new truck works and its pretty, but compared to a bumpside or dentside, it just isn't fun.
