home made gas pedal
- customcrewcab
home made gas pedal
well got most of my gas pedal made today. i still need to build the upper arm. i think it turned out pretty good. heres acouple of pics. some outside the truck and one mounted. it bolts into the existing holes.
- TheeMc
re: home made gas pedal
Looks great!
M
M
TheeMc
72 F-250 C/S
Why do we drive on a parkway, and park on a driveway?
"98% of all Dodge trucks are still on the road;
The other 2% actually made it home..."
72 F-250 C/S
- ToughOldFord
Nice work!!
- MadMaxetc
Looks awsome...only one thing...how does it connect??
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
FORD Girl
Oh yeah! nice work
- 71 LONG BED
Nice work! I made a brake pedal that looks like that a few years ago for my father in-law, to match his gas pedal.
John Member #1549
- GT-Racer
- marz68
- customcrewcab
well i still need to build the upper arm. i need to get a throttle cable before i finish it. a set screw will make it so i can adjust it.MadMaxetc wrote:Looks awsome...only one thing...how does it connect??
- 69bumptruck
Damn dude! You got some skills! Plan on making any interior stuff? Or have you already?
- binder56jd
professional grade workmanship
now serving #235
now serving #235
- customcrewcab
Re: re: home made gas pedal
yea. post them a long time ago. dimmer cover, viser holder, key trim, rear doors handle covers.69bumptruck wrote:Damn dude! You got some skills! Plan on making any interior stuff? Or have you already?
- customcrewcab
somthing not working right. dimmer theres twice. heres some other parts
