headlight problems
- boots
headlight problems
On my 67 the headlights are having some problems. The brights work fine every time I turn them on. But when I turn them off to just put the headlights on half the time they don't come on. A week or so ago everything worked fine...Yesterday only one of them would turn on, the day before that I had nothing, and today none of them come on again. I really don't know much about electrical, so what do you guys think I should look at?
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
re: headlight problems
well, don't laugh but i had a similiar problem with the headlights on the 69. It would go out and then when i parked it, the lights would be working part of the time. The problem became the dimmer switch on the floor of the truck. Replaced it and have not had the problem again.
- 68F250
Yep, dimmer switch.
Try exercising your switch, step on it a gazillion times. That will get you lights until you can replace the switch.
Barry
- heep70
Yep, Yep, dimmer switch.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
