Reverse lights
- gramsay
Reverse lights
When I purchased my 1967 ford f100 the previous owner had put a toggle switch on the dash to activate the back up lights, where is the switch on the transmition and if it is broken is it easy to replace?
- gramsay
re: Reverse lights
manual transmition, 4 on the floor. The engine is an inline 6, 240
- 72hiboy4x4
it should be in the shift tower of the tranny (right near the gear shifter under the floor)
not hard to replace, once you get the seat and the carpet and the tranny tunnel cover off.
