71 F100
What is this light for?
Dash Light?
Dash Light?
Re: Dash Light?
That is the brake warning light.
It's supposed to warn you of a brake fluid leak.
Re: Dash Light?
Thank you sir
Re: Dash Light?
Wow. I thought it was for something else. Anyone know how to get the light to work correctly
Re: Dash Light?
It's wired to the brake distribution block.
There's a part inside the block that needs to move freely, then you bleed the brakes until the light goes out.
If a brake line blows the part moves over and turns on the warning light.
