1966 4X4 front axle in 1966 F250 frame
I cannot find any info yet here on this. I am wondering if the coil spring mount front drive axle from a 1966 F100 4X4 will fit into the mounts of a 1966 F250 2 wheel drive frame. In other words convert the F250 2X2 to F100 4X4. Thanks.
Re: 1966 4X4 front axle in 1966 F250 frame
The problem with converting 2wd to 4wd is the big crossmember in the middle .
You're much further ahead buying a late 70s 4X4 and putting your body on it.
The later trucks have disc brakes and power steering.
The later trucks have a 2 inch longer wheel base and the rear of the frame is a little wider , but that's easier to deal with
than trying to convert a 2wd frame.
- Manny
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
