4x4 hubs
- eggman918
Re: 4x4 hubs
I do not think so from what i have seen the 78-79 hubs have the lockout splines as a part of the hub and on the earlier style the lockout splines bolt to the hub with the rest of the lockout assy.
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
Re: 4x4 hubs
Ya I would use the complete rotor and hub if it will fit on the 78-79 spindle
- cstoyer
- Manny
Re: 4x4 hubs
Yeah nope... The spicer lockouts where specific to closed knuckle Dana 60's, and also the hd 44.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Re: 4x4 hubs
The 76,77 highboy has them with a 44HD
That's why I was thinking even if you had to use knuckles, spindles & outer axle shafts they would work.
Basically use a 1979 44 high pinion housing in a Highboy truck
