360 FE 5 speed swap?
Anybody swap a 5 speed tranny in there truck with a 360? Just curious. I want to know with what transmission? Bell housing? Adapter? Do I have to get a different t case? Or different drive lines?
- eggman918
Re: 360 FE 5 speed swap?
The NV-4500 or TKO-500 or getrag-360 would be good bets with the divorced T-case you will use a 2WD trans and will need to change out the intermediate shaft and i would imagine the trans's input shaft...
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
That sounds difficult and expensive for my 16 year old self.eggman918 wrote:The NV-4500 or TKO-500 or getrag-360 would be good bets with the divorced T-case you will use a 2WD trans and will need to change out the intermediate shaft and i would imagine the trans's input shaft...
- HIO Silver
Tremec TKO-500... it will bolt to a stock FE bell if ya spec a shortened input shaft. I'm using the mechanical clutch linkage too. The trans is about one inch longer than a C6.
It's doable... even on a 4x4.
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
HIO Silver... where does that shifter come through the floor? Looks like it would come through under the bench seat. Thanks.
- tnab1970
cannonman67 did a NV4500 conversion in his thread " I call it the bruise.." i think he goes into some details if I'm correct. you should check it out.
- HIO Silver
Right there.... So long as you use a "candy cane" shift arm it will clear the bench when it is all the way forward in its tracks. But I eventually swapped to '70 Mach 1 buckets.dave1972 wrote:HIO Silver... where does that shifter come through the floor? Looks like it would come through under the bench seat. Thanks.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Thanks for those pics HIO. I will have to get ahold of you when I start my crew cab project.
