Thanks Steve.ultraranger wrote:Very nice work, Bobby!![]()
I guess this means you're no longer a brake tubing virgin.![]()
The only thing I see that you MAY have a problem with is the large line fitting on the rear of the valve. You may have a problem running a line off it, since it looks like it's in tight confines. If you can bend a line off it, It may be difficult to get your line wrench on the fitting to be able to tighten/loosen that fitting.
http://i227.photobucket.com/albums/dd3/ ... 6f1e0d.jpg
I had a 180-degree bend coming off the rear of my brake valve and I just barely had room to get the line wrench in to tighten that fitting. --and this was without the valve bracket being located behind this fitting or with the MC sitting right on top of it.
[ Image ]
Hopefully, it won't turn into a big problem requiring modifications to the bracket or valve mounting location.
No, that rear line shouldn't be a problem. I planned it like that. I wanted it to be real tight. I have a special wrench that should make it easy.
