I am a very novice welder but I want to buy one and learn how. Which is most forgiving and which is easiest yo use? which gives the best results?
Thaks guys
[/quote]quote="spartman"]What exactly is TIG welding anyway?
I have looked up some info on the net and it almost looks like high power soldering.
Wikipedia wrote:Gas tungsten arc welding (GTAW), also known as tungsten inert gas (TIG) welding, is an arc welding process that uses a nonconsumable tungsten electrode to produce the weld. The weld area is protected from atmospheric contamination by a shielding gas (usually an inert gas such as argon), and a filler metal is normally used, though some welds, known as autogenous welds, do not require it. A constant-current welding power supply produces energy which is conducted across the arc through a column of highly ionized gas and metal vapors known as a plasma.
