horn
alvinator
horn
Post by alvinator »
I have a set of air horns off a diesel train and I am looking at putting them on the 68. I was thinking about taping into the wire for the main horn and putting in a toggle switch so that I could switch between the two horns, do you see any problems with doing this?
Billybobjunky
re: horn
Post by Billybobjunky »
as far as I see, nope. Long as all either horn needs to run is straight charge, there wont be any problems with splitting it between whichever you want for the moment. Should be fine.
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
fordman
Post by fordman »
how much voltage do they pull.
68F250
re: horn
Post by 68F250 »
Train horns? How wimpy! You need one of these, yeah it's got a hemi.
Barry
FORDification
Site & Forum Admin
Site & Forum Admin
re: horn
Post by FORDification »
I'm thinking with something that big you might want to install those with a relay, depending on how much juice they'd need. (I'm talking about the train horns, BTW. Barry's air-raid siren looks to be fully self-contained.) ;)
That air-raid siren would be the perfect way to get the point across to tail-gaters, wouldn't it? Just load it into the back of your truck facing rearward, and then let 'er rip....it would probably peel the paint off the hood of the guy behind you, though! :lol:
fordman
Post by fordman »
that thing look like it spins. you could peel paint on all four sides of you.
Yota
re: horn
Post by Yota »
man, that thing is a beast...
alvinator, i put a air horn from a big rig on my toyota with a switch like you described, so i could switch between the air horn and stock horn. no problems whatsoever, it worked great.
1968 F-100 4x4, 390 4spd. 35" bfg m/t's -FOR SALE!
1980 Toyota 4x4 - new engine is in!
my picture gallery
Big D's 69
Re: re: horn
Post by Big D's 69 »
68F250 wrote:Train horns? How wimpy! You need one of these, yeah it's got a hemi.
Now that is a horn.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
fourtss
re: horn
Post by fourtss »
kool all u need is a trailor to tote it around on :woohoo: :hi: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
capeclassics
re: horn
Post by capeclassics »
I wonder if there's a jack for an IPod on that Air Raid Siren.....hmmmm.
bleedfordblue
re: horn
Post by bleedfordblue »
wait a minute... how does an air horn run on an electrical circuit??? big trucks have engine driven air compressors. you will have to find a small electric compressor to run an air horn.
I'd rather be shooting yankees....
and terrorists.
alvinator
re: horn
Post by alvinator »
not necessary, i was thinking about putting the tank on the frame and just fill it up every so often rather than putting a pump on the truck.
fordman
Post by fordman »
you could get one of those tire compressors that plugs into the cigarette lighter.
Yota
re: horn
Post by Yota »
i put together an on board air setup and used a York a/c compressor from a Volvo, and it's set up to pump air instead of freon. so it's engine driven, and FAST. i have a 3 gallon tank mounted under the bed of the Toyota, and the compressor will fill the whole system (tank, lines, etc..) from 0-100 psi in about 30 seconds with the engine at 2000 rpm.
then i have an electric over air solenoid on the air horn, and the electric curcuit only controls which horn gets the juice when i hit the button.
my picture gallery
bleedfordblue
re: horn
kool
and terrorists.
