location of 302 perches
No tech discussion, please
elvis67
Post by elvis67 »
HI guys
I looking for correct location of 302 perches on 67 frame I know that the 302 was not offered in 67. I know that i will have to drill some holes ,i just want to be sure where. If some of you ,have a stock 302 in there truck and be nice enought to mesure the perch holes to the middle of the coil spring or any other measurement that could be helpful.
My stock set-up was 240 with 3 on tree. Swap for 302 with C4.
see pics Thank you very much
Fraser
Re: location of 302 perches
Post by Fraser »
If you go to this sites homepage > technical art. scroll down to engine perches, all your questions will be answered. However, my '67 has a 289 from a previous owner, mounted on the 352 mounts, and has had none of the driveshaft woes mentioned, and a 1/2 inch spacer under the transmission mount would likely solve any, if there were.
F. Noble, Saskatchewan.
