Where is this leak coming from?
Bigcalhoun
Post by Bigcalhoun »
Gents,
After getting tired of oil sitting on top of the timing chain cover I pulled off the front end of the engine and put in fresh gaskets for the first time in 15 years. Two weeks later, the leak is back. Assuming the gaskets are properly installed and sealed, any thoughts on where to look next?
I'm pretty sure it's not the valve cover.
[image]1521[/image]
'70 F100 Sport Custom, 302
72Ranger390
Re: Where is this leak coming from?
Post by 72Ranger390 »
if its the valve cover you could see oil running down the side of the block somewhere. did you look?
2005 Ford f-150 Lariat supercab 5.4
1972 Ford f100 Ranger 390, C6 trans, 9¨axle
two-bit
Post by two-bit »
Where the dizzy shaft/housing goes into the block ? Intake maybe ? Just a guess.
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
72Ranger390
if the leak was coming from the valve cover, you would see oil running down the side of the block somewhere. besides that puddle the block looks pretty clean so probably not that
two-bit wrote:Where the dizzy shaft/housing goes into the block ? Intake maybe ? Just a guess.
Agree. Distributor or maybe the front intake/china wall.
Bigcalhoun
I pulled the distributor and no sign of a gasket so I'm assuming the last 51 years were unkind to the original one and it finally disintegrated. A new gasket is in order so hopefully that will help or eliminate the leaking. Thanks for the tips.
two-bit
Post by two-bit »
Let us know how it works out. Always good to know the solutions for the future.
Johnnewc
Post by Johnnewc »
To be sure you could clean it all up well then spray it with foot powder. It seems silly but you will be able to see an oil leak right away when it shows up on the white powder. That is what I do.
Bigcalhoun
Pretty sure it’s coming from the dizzy. Put a new o ring on it. So far so goof.
P.s. great suggestion on the foot powder.
