'65 short bed body on '67 frame
What are the sticking points here? I assume the body mount is slightly different, just because. Anyone done this?
Pete's Ponies
Mustang RUSToration & Performance
Re: '65 short bed body on '67 frame
Are you going to be putting the 1965 short body box on a 1967 short body frame? I don't have any help with this, but you might also check out the Slick website, it is for 1961-66 Ford trucks. There may be someone there that has done this swap.
truck: http://www.slick60s.com/
Hope this helps!
Hope this helps!
I just found this thread it talks about Slick vs Bump frames, it doesn't mention if it is long frame or short frame:
http://www.fordification.com/forum/view ... =5&t=28071
Regards
Regards
