69 f100 team build
wndsofchng06
69 f100 team build
Post by wndsofchng06 »
So finally started on the F100 project. Since I have a million things going on, my buddy and I are going to build it together. We have a 69 f100 shortbed that we've stripped to the frame. New mounts and floor pans have been put in the cab and now we're focused on the framed. Going through wire wheels for sure!
Going with the 302 (not pictured) and 3 speed.....
Relocating the fuel tank
wndsofchng06
Re: 69 f100 team build
Went to LKQ today and got the whole front suspension from a 79... yay for disc brakes
Mercury100
Post by Mercury100 »
Is that fuel tank from a dent side behind the rear axle mount?
wndsofchng06
Yes. Although it doesnt tuck into the frame as nice as I want, so I will modify it later.
wndsofchng06
Trying to keep the motivation by doing little bits after work.
One of the backing plates was bent and badly gouged, so I trimmed a small bit of metal and welded it in, no where near perfect but will do for behind the rotor....
wndsofchng06
Also painted some smaller parts
and the sway bar
Then after lots of degreasing and wire brushing, gave the I-beam setup a final rinse.
wndsofchng06
UGH!! Now that we've spent hours cleaning these up, we realized the one spindle's bearing surface is just trash.... looks like a bearing flew apart in there sometime. :-(
:cuss: :cuss: :cuss:
wndsofchng06
Found another junkyard 79, pulled the right side suspension, all good! Cost way more at this yard though. Now back to cleaning....
wndsofchng06
Got more work done...
Sway bar links:
both sides of front suspension painted and reassembled
And whether you hate the color or not, I just couldn't paint one more black frame... HA HA HA unfortunately this photo is crappy and it looks purple, but its really a medium blue.
Bullitt74
Post by Bullitt74 »
Impressive work thus far, guys! Looking forward to following your build! 8)
Steve F.
Red Deer, Alberta, Canada
8)
jzjames
Post by jzjames »
Looks good.1st blue frame I’ve ever seen :thup:
Keep doing that kind of stuff 8)
wndsofchng06
Thanks both!
wndsofchng06
Between the heat 95+ daily and work, progress has been a bit slim... Cut one coil off the springs and painted, also mounted the steering box.
Manny
Post by Manny »
Like the build thus far very nice progress, and with the discs you will be happy. Also give you props for painting the frame different. BE brave and be bold. Somebody has too!!! :thup: Keep it going.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
wndsofchng06
