Mild bed corner rust
I have a couple small rust spots both in front and behind the rear vertical bed seam on the lower bed corner. Is that seam gonna cause me any trouble if I just put in a single patch panel, cutting over the seam. The seam is gonna get filled anyway. Pretty small patch 6x6 or so. Thanks
Re: Mild bed corner rust
Yes just cut out the rust and weld one patch.
You are going to" Weld "the seam the rest of the way aren't you.?
take pictures so i know how to do mine...
