So my transmission c6 is leaking i think from where the kickdown brackett mounts to. Is this possible or should i be looking at other places. Gonna tighten it.all up a bit more and see if that helps.
D
Leaky tranny
Leaky tranny
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- 69Ford
Re: Leaky tranny
I had a leaky tranny replaced the pan gasket a couple times. It turned out to be a leak in the O ring of the tranny dipstick tube. C6
Re: Leaky tranny
Yes this is a very common place for our Ford automatics to start leaking. It's called the "selector shaft" (which the kickdown bracket and shift linkage actually hook onto)."1guydude"]So my transmission c6 is leaking i think from where the kickdown brackett mounts to. Is this possible or should i be looking at other places. Gonna tighten it.all up a bit more and see if that helps.
D
There is a seal about 1/2" inside the aluminum casing there, (that seals around the selector shaft). Part #7B498 behind the turn signal switch in this image.
As far as I know there is no way to replace that seal without dropping the pan on the transmission / removing the valve body / then removing the selector shaft and replacing the $5.00 seal. I'd source out a written quote from a local tranny shop on this repair. And don't run the tranny long low on fluid or you'll be sourcing out a rebuild on the transmission!
Last edited by basketcase0302 on Tue Sep 05, 2017 5:00 am, edited 1 time in total.
Re: Leaky tranny
Well dang. Not what i wanted.to hear but what i wanted tk hear. Thanks guys. Ill have to get the truck to a tranny shop down the road and tackle both those.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- BobbyFord
Re: Leaky tranny
Easy DIY fix. A trans shop will charge at least an hour labor to replace the seal and o ring.
Re: Leaky tranny
Well mr bobby ford. I have a rear seal i think so i might just try and tear into it and diy fix it myself. We will see
Thanks all
D
Thanks all
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- Jacksdad
Re: Leaky tranny
Just reading this after cleaning up the oil leak in front of the complex before the landlady see it
In my case, I'm pretty sure the front pump seal on my C6 is getting ready to lay down and die (if someone hasn't already administered the last rites while I wasn't looking). The poor truck sits for such long periods, I'm sure all the seals are hardening up.
1guydude - if it makes you feel any better, at least you won't have to pull the transmission to fix your leak
