Cab Fuel Tank Color?
- jimilivz
Trying to straighten out the fuel tank mess on my 68 F250. One of the po's replaced the original, non emission tank with one from a 73 truck. It is painted black. Would the original in cab gas tank put in my truck have been painted or unpainted from the factory? My truck is an original deluxe two tone truck with lunar green over Wimbledon white. LMC sells the right tank that I need, just not sure if it is bare metal or primed. Many thanks.
68 F250 CS Ranger 390 C6
- Jacksdad
Re: Cab Fuel Tank Color?
I needed one for mine, and found quite a few in the wrecking yards before I settled on the right one (ie no holes punched in them to drain the fuel). All the ones I saw - including the one I bought - were painted black if memory serves.
The tank in my '68 is painted red the same as the rest of the truck and is all original so I would say it would be whatever the original color of the truck was...........mine is a base model so I cant see a nicer model not being painted......
1997 Honda CBR 900RR
- 67mann
- HIO Silver
My "New Lime" 70 Custom's in-cab tank is painted black.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- 67mann
- colnago
I have the original cab tank in my '67. It was also Lunar Green over Wimbledon White. The tank is Lunar Green, just like the rest of the cab.
Joseph
Joseph
- jimilivz
Thanks all. Current plan is to get the new tank/s unit from LMC, and have it painted lunar green.
