Any experience with cheap eBay hei distributors?
I was browsing for electronic ignition upgrades for my '69 F100 with a 302 and ran across this - http://m.eBay.com/itm/301802103239 . The truck will not get a ton of use or go far from home. Just curious if anyone has tried something like this. Thanks!
1971 F-250 360 ci automatic trans - sold
Currently working on a 1969 F100
- Ranchero50
Re: Any experience with cheap eBay hei distributors?
I read through that post also. It was somewhat helpful but I'm looking for people that actually used a cheap hei or know some one who did. I searched the internet and it seemed like people that actually bought them, thought they were OK. A few had issues. Most seemed to have never used one but had a lot of opinions. Since you guys are the bumpside gurus, I hoped someone could chime in with first hand experience. Thanks again!
I swapped over to the Ford Duraspark system in my '64 Fairlane. Bought a new WPS distributor and ignition box from Rockauto.com. Distributor was $45, a perfect fit and worked great from the first turn of the key. Been running daily for 5 months now without any problems. I would buy it again if I need it.
- 71PA_Highboy
I have one... and I can't use a radio in the truck because of all the ignition noise.
I am running it off the harness pigtail that was for the stop solenoid, so there is no inherent RF choke on the circuit.
Other than that it seems to work great.
I will probably move to a duraspark this summer so I can have some tunes again.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Just put one in that I bought from Amazon for like $80.00. HAd to buy the one conecter [hot and tac wires]. Runs like a charm. Pulled outa dura spark setup someone else put in. Wired the hot wire right to the ignition switch. Had to dent stock air cleaner slightly to clear
- colnago
No experience, but I bought one for an FE rebuild. Finally decided to go with a Duraspark setup. So, I have an HEI distributor for sale ...
I did like the idea of a single-wire setup. Clean! My two concerns:
1. I heard it ran hot, and the electronics can poop out at any time (yes, this can happen with any option).
2. The peg holding the gear on the shaft would work its way out, and the gear would fall off (again, this could happen with any distributor, but it was a concern with the Chinese HEI option).
Just my two cents,
Joseph
Just my two cents,
Joseph
Go to the FORDFE forum and look up a guy named Faron Rhodes. He sells a modern drop-in Duraspark style distributor.
In my opinion, nothing looks worse on a Ford than a GM style dizzy.
1970 F100 Ranger 2WD
project link: http://www.fordification.com/forum/view ... 22&t=83642
- BobbyFord
If you have a stock daily driver or weekend driver anything beyond a Pertronix is a waste of money. JMO.
