rad support mounts
IN2FORD
rad support mounts
Post by IN2FORD »
Where can you find the steel washer/sleeves that go through the rubber mounts under the rad support?
Barry
Canonman67
Re: rad support mounts
Post by Canonman67 »
Mine didn't have sleeves through them. I don't believe they're used there. Washers and the rubber are sold at the usual sellers (LMC, etc).
IN2FORD
Post by IN2FORD »
It shows them here. Maybe I don't need them as long as I have a stout washer on either side. Part # 00163
Barry
Wilfred of Ivanhoe
Post by Wilfred of Ivanhoe »
So long as it doesn't bug you, you should be able to use any washers that fit and give you the needed spacing. This is how I have always done it. My dad too. His dad too.
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
Most of the aftermarket replacement hardware kits for cab mounts and rad supports are just bolts, nuts and washers. The originals were stamped/extruded/welded tubes and washers. A couple of mine were in bad shape and had to cut them loose. I got some used one's from a member and made my own out of some galvanized steel conduit and cut some thicker washers on our laser at work. Had a friend weld them for me. You can see them hanging in the center of this photo of my paint booth.
IN2FORD
Post by IN2FORD »
I thought about just welding some tube to the bottom of thick washers. Good to know it will work with or with out.
barry
