Head lights
- ezmerf
Head lights
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=83
I ordered me some of these http://www.lmctruck.com/icatalog/fb/full.aspx?Page=83 Just curious if anyone else has tried them? Was gonna do a light bar but needed a head light anyway so figured I'd see what these do.
Reason: Edit title which looked like spam
- HIO Silver
Re: Head lightshttp://www.lmctruck.com/icatalog/fb/full.aspx?Page=83
Which one? And did your order a relay harness?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- Ranchero50
I have a set of similar one that lasted a day on the truck. They had a red spot in the middle which didn't bother me a lot but the flat lens cover completely ruined the trucks look. They also cast a blue light that looked bad and the focus wasn't that good. I went with a pair of Sylvania extra-visions. I checked and was only losing .25 volts through the wires to the lamp so I didn't go with relays. After running the truck at night the new bulbs are @ 10-15% brighter than the old '68 FoMoCo's I had in it.
- ezmerf
Well didn't order special harness and last night was the first I got to try them.Went down to my pond with lights on dim came back up on bright.Well after afew moments they would flash off and on.So any ideals whats the problem? Thanks for the help.
- Ranchero50
Re: Head lights
Excessive amp draw causing the CB to trip. I forget where it's located, I think it's part of the switch on ours.
Re: Head lights
I believe he is correct. It is a little thermal breaker/switch in the headlight switch assembly itself. Over time they get weak and open when hot then reclose when cooled off. I had a 1965 Mustang which did the same. New switch should help mitigate that.Ranchero50 wrote:Excessive amp draw causing the CB to trip. I forget where it's located, I think it's part of the switch on ours.
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- HIO Silver
... and that's why I asked if ya bought the relay harness.ezmerf wrote:Well didn't order special harness and last night was the first I got to try them.Went down to my pond with lights on dim came back up on bright.Well after afew moments they would flash off and on.So any ideals whats the problem? Thanks for the help.
Instead of the headlights' current going through the switch to the headlights, all the switch will do is provide a low curent signal to engage the respective relay ( hi beam or low beam) thus sourcing the voltage (and current) directly from the battery.
Direct experiential events regarding this particular issue was apparently necessary.
Your next move should be blatantly obvious.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- ezmerf
Re: Head lights
Thanks, sort of figured I'd need the harness should have ordered then.What you get for being cheap.
- ezmerf
Re: Head lights
Finally ordered the harness maybe that'll do the trick.
- ezmerf
Re: Head lights
Well LMC can kiss my butt.The harness they send has a 3 prone connector the one on my truck is a 4 prone.They say the harness they sent is the right one.Any ideal how I can make it work?
Re: Head lights
That's why LMC has to do so much advertising on car and truck shows. They have cheap products and don't stand behind their crap.
1967 F-100 4x4 custom cab.
- 71PA_Highboy
Re: Head lights
Pics of the connectors?ezmerf wrote:Well LMC can kiss my butt.The harness they send has a 3 prone connector the one on my truck is a 4 prone.They say the harness they sent is the right one.Any ideal how I can make it work?
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 69Ford
Re: Head lights
I bought the LMC harness my truck has the three prong headlight connectors and it works great. Although I wish the relays were the standard bosch type so if one goes all I need is a trip to the parts store.
- ezmerf
Re: Head lights
I gave up on trying to get a picture on here.One from LMC has a flat 3male blade connector my truck has a 4 prong connector .2male 2female.
- 71PA_Highboy
Re: Head lights
put a pic on photobucket and link it?
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
