'67-'79 Ford Truck Parts
- fordtruckparts
Hey there guys I've got a bunch of extra parts kicking around here, need to make some more room in my shop and yard. I have a '71 parts truck as well as a bunch of extra pieces from '67-72's kicking around. I also have a '79 Parts truck and again, various extra pieces from the '73-'79 parts. Let me know if there's something odd or obscure you need, I don't have everything, but I just might have it
1948 Dodge 2.5 Ton, 1959 International Harvester BC-180, 1959 Willys Pickup, 1965 Impala HT, 1965 Galaxie Convertible, 1967 Mercury M-100, 1969 F-250, 1971 F-250, 1976 F250, 1978 F-350, 1979 F-250, 1980 Dodge D-300, 1984 F-250, 1986 F-150, 1987 Chevy Monte Carlo, 1988 F-150, 1988 Mustang, 1990 F-150, 1994 Camaro Z28 LT1
Re: '67-'79 Ford Truck Parts
I need rocker panels mainly the part that curves up in the front of the door pillar. This is for 72 F100
- fordtruckparts
Hi, I'm sorry I can't help ya there, I have the same problem with my two trucks i'm trying to restore
- 69Ford
Do you have a stock radio and knobs for a 69
- colnago
Do you have the courtesy light (dome light) switches and brackets in the door jam? I have a '67, but I don't think these are specific to the year.
Thanks,
Joseph
Thanks,
Joseph
- jimmy828
i'm adding power steering to my 69 and what i'm looking for is matching harmonic balancer and 2 grove pully. The engine is a 360.
Looking for the right side inner fender bracket that bolts to the cab and the inner fender mounts to it for a 69
Need a steering wheel if you have one. Thanks!
Looking for 67 driver side metal door panel.
67-69 headlight trim/doors for the grill, the aluminum ones.
Looking for the Drivers side (possibly both) STEEL headlight door/bezel.
How bout a black or Red dash pad ? buford
- Menace Kustoms
Do you have the 1-1/4" bright side trim (1967 style) for an 8-foot bed to cover the line between the two colors of paint?
