I am installing a 5 inch Autofab lift on my daughter's 71 F100 and need to engineer some bumpstops. I had to remove the factory rubbers because the kit utilizes larger F600 springs, plus they weren't real strong when the truck rolled off the assembly line. I do not want to put air bumps in but rather a compact mount under the frame instead of beside it. The truck will only see light off-road use but it needs to function well if she finds a dip and look good too. I've been told billet aluminum is acceptable as most of the high density foam or rubber units will squirt out after a few harsh cycles. I don't want to go to the extreme of billet but I don't want a lightweight rubber piece either.
Please let me have your opinions on this.
Tony
Prerunner bumpstops
- mybros71
Prerunner bumpstops
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
