Zero leaks at any other time but when I shut it down it spits a good 2 oz of oil out from around the oil filter like it’s not seated properly. The filter is in tight and if it were cross-threaded in there or something it would leak all the time I would think so for some reason there seems to be an abnormal amount of oil pressure just when I turn the engine off.
It just started doing this about 6 weeks ago. The only potential cause I can think of was that I had one huge backfire out the manifold (before I dunked and rebuilt the carb) that was powerful enough to blow the exhaust gasket on the left side.
Any thoughts?
Thanks,
John
FE 360 engine oil leak on shutdown only
Moderator: Ranchero50
- Jondon
When the going gets tough, switch to power tools.
- heep70
re: FE 360 engine oil leak on shutdown only
I have bent pushrods with a backfire on my 460.
Man that is wierd. The only thing I can think of is that the lifters that are under pressure are pushing the oil back. ?????????????????????
I am sure someone here knows. Good luck. I am interested in hearing the result(s). Greg
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- Jondon
Changed the filter, problem solved. I guess I'm conditioned to expect the worst.
I have a new question on oil filters now though....
