Ok, I'm about to ask the dumbest question ever. Especially since I was born and raised a ford guy. have owned several 67-76 ford trucks and broncos and I work on 4wds for a living.
But what exactly makes a hiboy a hiboy. I know they are taller but,was it just a term given to trucks of that era? Or is it a suspension thing or ?
Please don't flame me to much.
Thanks in advance
Will
Highboy?s
- fireguywtc
Re: Highboy?s
For what I have read here, a highboy is an aftermarket term that refers to a 67-77 F250 4x4 that have the divorced transfer case. It has no real meaning and does not mean that they were lifted from the factory or whatever. It only applies to the F250, not the F100.
Bill
1967 F-250 LWB 2WD 352 V8, 4spd manual, true duals, 122k original miles (currently being restored)
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
Re: Highboy?s
Thanks for the reply.
Will
Will
- Hawkrod
Re: Highboy?s
That is the correct answer and to expand on it, the 77 1/2-79 are usually called Lowboys. The earlier F250's used s specific chassis design with a relatively straight and narrow ladder frame while the later trucks used a more modern step down wider frame design. The trucks really are not too much different in actual height but the chassis design is dramatically different. If you park a 77 Highboy next to a 77 1/2 Lowboy there is a differeance but depending on GVWR options it may not be much. A 6750 GVWR Highboy parked next to a 8400 GVWR Lowboy is hard to differentiate which is which in profile! Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/veh ... 9&detail=1
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
