1971 360 head identification
Engine Forum Archives
Moderator: Ranchero50
ajsmolik
Post by ajsmolik »
Hey again,
Sorry, i posted this over at FTE first - new to the forum.
I just bought this 1971 Custom 2WD 360. (See rad. support question in General Forum)
Anyway, I'm just sure the motor has never been rebuilt before I laid my greasy hands on it. The heads have two different casting numbers: C8AE-H on the right and C8TE-6090-G on the left.
Is the one on the left a CJ? Or just a replacement head? Is it possible that it was produced that way?
:hmm:
Thanks,
cobraF100
re: 1971 360 head identification
Post by cobraF100 »
It probably a Remanufactured Engine.
C8AE-H : is a 68 small port head used on many diiferent Car and Trucks.with about 70cc's
I cant find a Head with that casting # (C8TE) BUT I found that the 360 used a C8TE Crank...
6090 on a Head was used as a way to tell it was a High Performace but with FE's you never know....
Chris
Never Forget Our Soldiers
heep70
Post by heep70 »
They both are 1978 and the "A" is for "full size Fords (Galaxies) and the "T" on the other head is for "Truck". The "E" is for where they were wharehoused at. Ford used an "X" in place of the warehouse code for special muscle car parts.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
cobraF100
Post by cobraF100 »
The C8AE-H came out in 1968.....
Chris
heep70
Post by heep70 »
OOOpppssss. I guess I should proof read what I write. Thanks cobraF100
Greg
ajsmolik
Post by ajsmolik »
Thanks for the replies,
Musta' been a rebuilt engine.
Think there's any reason I can't transform this engine into a 390? (The cylinders measure 4.050")
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
It's an easy upgrade, relatively speaking. Just have to use the 390 rotating assembly (crank, rods and pistons). If you can find a 428 crank, that'll be even sweeter, giving you a 410.
oldschoolrods
Post by oldschoolrods »
Or if the block can take it, bore it out some more and use the 428 crank to have a 428 ;) 8) :evil:
Re: re: 1971 360 head identification
oldschoolrods wrote:Or if the block can take it, bore it out some more and use the 428 crank to have a 428 ;) 8) :evil:
But don't get your hopes up, it is highly unlikely that the block will take a std 428 bore. (only way to tell for sure is a sonic check)
