Just dont know what to do first, I have to put in new rockers, and floor pans. any idea what to do first. and ideas, is it better to do floors then rockers or what
thanks
chris
whats to do first
- flyboy2610
re: whats to do first
Are the rockers rusted completely through, so that if you removed the floor pan there would not be a solid piece of metal from the front of the cab to the back?
If so I would do the rockers first, to strengthen the cab when the floor pans are removed.
I would also recommend removing the doors. That way you won't have their weight acting as a lever trying to pull the cab out of alignment.
Red Green
you'd better be right.
Red Green
the rockers not really rusted through there are some holes i think maybe i can just put in some patchs, but just considering replacing the hole rocker panel,
- flyboy2610
In that case I think it's more a matter of preference.
When you replace the floor pans it's a good opportunity to replace your front cab mounts if they are rusted out.
This is how I did mine.
http://www.fordification.com/galleries/ ... ?album=238
Red Green
Red Green
nice pics, show alot of detail, did you use a seam sealer when you put in floor pans and cab mounts, wheres a good place to get floor pans, LMC up the street from where i live put hgeard there pans arent that great. The owner before me on my truck already did cab mounts.
Re: re: whats to do first
flyboy2610 wrote:.
I have not done sheetmetal work before, but the people I spoken with stressted leaving the doors on. They said when you replace the doors that the gaps may not line up as before. If the cab flexing is an issue just temperarly welded bar stock in in an X pattern to keep the cab from shifting. Again this is what I was told, not what I have done.
- flyboy2610
When I did my trucks cab mounts and flor pans, the front clip was off the truck. I did like the thought of all that weight hanging and pulling on the cab when there was no fllor pan or cab mounts to resist the pull.
When we put the doors back on it took les than 5 minutes to get them lined up all the way around.
Red Green
Red Green
