welding bottle cost
70shortwide
welding bottle cost
Post by 70shortwide »
heres the situation:
guy has a welder for sale. guy will be out of town all week. guy says he will make me a good deal on a welder that is a little smaller than I want, tonight only. doesnt include a gas bottle, since its 7 pm sunday night, I cant price a bottle at the local welding shop. I dont need a big bottle, a small one will do fine. Ive seen some about 2.5 ft tall. how much will one cost me to buy, not rent?
Caseys71
Re: welding bottle cost
Post by Caseys71 »
If I remember correctly a smaller cylinder will run you about $150 give or take a bit, then about $20 to fill it at your local welding supply house. You could probably do some flux first and keep looking for a used cylinder, just make sure it's new enough that it's still refillable :thup:.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
black70cs
Post by black70cs »
I bought mine, was about 150. The guy at the welding supply place they will pretty much pay for themselves in about a year or so. That was for 75/25 co2/argon about 35 bucks to refill
fordman
Post by fordman »
thats about what it is to refill them here. 75 for oxy. and about 40 for ayctelne
FORD428CJ
Post by FORD428CJ »
Caseys71 wrote:If I remember correctly a smaller cylinder will run you about $150 give or take a bit, then about $20 to fill it at your local welding supply house. You could probably do some flux first and keep looking for a used cylinder, just make sure it's new enough that it's still refillable :thup:.
The only problem with flux is that you cant weld over it with straight wire after that! Been there and done that. Keep that in mind before you weld. JMHO
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
FORD428CJ
Post by FORD428CJ »
Also I use CO2 in my mig. Works well for beer making too LOL
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
Straight CO 2 will work for steel but a C25 argon mixture will make a smoother weld.
If you're grinding and filling over it it may not matter , but for appearance it might.
Also if your doing body work over flux core , clean it up as best you can.
Sand blast if possible because the flux can react with the body filler.
