Ignition switch question
dcbullet
Post by dcbullet »
Hi:
I have problems with my ignition switch in that I have to jiggle the key to get some of the interior electronics to work (e.g. radio, gauges, etc.).
So I'm planning to replace the switch. Here's my question. For any of you who've had this problem before, did you need to replace the lock cylinder as well? I'm wondering if I stick my old lock cylinder in a new switch if the problem will remain.
Thanks in advance.
crazy larry
Post by crazy larry »
you can re-use your lock cylinder in a new switch.
you'll need to have the key in the cylinder, use a sturdy straightened out paper clip to insert into the hole on the keyed face, turn key, and the key mechanism comes out.
i doubt the problem will persist.
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
heep70
re: Ignition switch question
Post by heep70 »
No, you should not have the same problem using your old cylinder and a new switch.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
68F250
Post by 68F250 »
Disconnect the battery before pulling the cylinder.
Barry
lobuck76
Post by lobuck76 »
turn key to accessory, insert paper clip. It will then turn another notch to left and let go. If I remember right.
'71 F-100
flyboy2610
Post by flyboy2610 »
Yup. You are correct, Lobuck.
Red Green
you'd better be right.
dcbullet
Post by dcbullet »
Thanks for all your responses.
gjc12
Re: re: Ignition switch question
Post by gjc12 »
68F250 wrote:Disconnect the battery before pulling the cylinder.
I second this! That's how I blew my fusible link.
1971 F100, 390 3-speed
dcbullet
Post by dcbullet »
Ok, all fixed. You guys were correct and it works fine now with the old lock cylindar.
What a relief. You can imagine how fun it was driving around and then the gauges, blinkers, radio, and fan stop working. Then I'd reach down to jiggle the key to get them working again and the engine would turn off. :doh:
flyboy2610
The switch in these old trucks is a snap to replace.
Try doing the one in a 91 Taurus. PIA.
Red Green
