1981 F-100 4 speed
papabug71
1981 F-100 4 speed
Post by papabug71 »
I have looked all over. Can you guys tell me what 4 speed Ford used in its 1981 trucks?? Its bolted to a 300-6. It has the same shift pattern as a NP435.
My in-laws have the truck. I never really looked at it until yesterday, since it the wrong generation & everything.
The truck is a 1981 F-100 (or 150), 300-6, 4speed.
Thanks guys. :fr:
Matt
1971 F-100 Sport Custom - My grandpaws truck
Been in the family since 10/3/'71 (Brand spankin' new)
Mine since 5/7/'94
302 / 3 speed / 3:25's
--Currently undergoing full frame off resto/mod--
NM5K
Re: 1981 F-100 4 speed
Post by NM5K »
I think those were the T&C 4 speeds with a OD 4th. That may be the
same as a "Clark". Seems I've heard some call them that.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
papabug71
Post by papabug71 »
I found it. Its a NP435.
Do you guys think it would work with my 302? Its bolted to a 300-6, so im thinking it will. From what I can tell, it isint equipped with a hydraulic clutch set-up. But the clutch linkage looks different to me. It still has a clutch rod very similar to my 71 yet it looks different.
So ill need a NP435 short drive shaft & flywheel..? What else.??? What about the clutch linkage.???
Matt
Mine since 5/7/'94
FordTruck
Post by FordTruck »
The straight 6's have the same bolt pattern as the smallblocks.
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
Thunderfoot
Post by Thunderfoot »
Just the bell housing part is different from FE to SB/6 the transmissions are the same. Just pull the trans and put it in the bell housing you have, use the clutch and clutch linkage you have.
Here is a web site that I use to see what transmissions were in what and the differences of them http://www.novak-adapt.com/knowledge/tr ... ateway.htm
Shayne
I'm not "Brand Loyal" Ford-Chevy-Dodge-Toyota I have them all, one even cross mixed...
If it Looks good and Works good then it's ok by me. Everything has its issues from time to time...
69 SWB (project) & 69 Highboy (driver/project)
http://s197.photobucket.com/albums/aa29 ... d%20truck/
http://www.fordification.com/galleries/ ... ?cat=10399
papabug71
Post by papabug71 »
Thanks for the replys guys. Im going to seriously consider swapping it to a 4 speed.
Thunderfoot, PM sent.
Matt
Mine since 5/7/'94
papabug71
Post by papabug71 »
Well, after actually crawling under the truck & getting covered in ticks, I have found out its actually a B/W T-18.
It has Borg-Warner stamped on the side of the case. The only reason it threw me off was cause reverse is to the right & down. They must have changed the reverse pattern on the T-18's at some point in time. Im use to seeing the old T-18's with reverse to the right & up.
The clutch linkage looks like it will work as well, its basically the same as my 71's linkage.
Im going to pull it next weekend, so i'll let you guys know.
Matt
Mine since 5/7/'94
fordman
Post by fordman »
the np435 has a aluminum top cover. and the T18 has a steel top cover. that is the way it was on our trucks anyway. i would guess it would be the same for the newer transmissions also. one ohter way to tell is how the shifter is held into the top cover. if the shifter can be removed by pushing down and turning the cap it is a np 435. if the cap screws off it is a T18. i hope it work for what you want.
papabug71
Post by papabug71 »
Thanks fordman. I did a little more reserch & found out that Borg/Warner changed the reverse location in 1978, to over & down. Just like a NP435.
Im going to spend all this comming up weekend pulling it & rounding up everything I need to put it in my truck.
Thunderfoot, that Novak website is freekin' awsome. Thanks for the link!
Matt
Mine since 5/7/'94
