Not sure what section.. Windshield for 68 f100
First_Ford
Post by First_Ford »
Do windshields from different years fit the 68 ? On newer windshields I have read that they are thinner than the original..do they make different weatherstrip ? My local pull a part has a great 78 will it fit? :?
Sorry if im in the wrong section...
Dustin
1968 F-100
fordman
Re: Not sure what section.. Windshield for 68 f100
Post by fordman »
67-79 trucks will fit. when you get it cut the rubber off of the old one to take it out. new rubber gasket can be bought to reinstall it with. just get the rubber for your year of truck. and if you have the windshield chrome you will need the grooved type of gasket.
mjhaltom
Post by mjhaltom »
LMC lists the part #s as the same, so I say grab it.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
First_Ford
Thanks for the fast response!!!!! I will pull it this weekend....just one more question.. The trucks previous owner installed some seats that I want to take out. I don't have the rails to mount a newer model seat. would rails from 73-79 bolt up to my 68?
Dustin
1968 F-100
fordman
Post by fordman »
the rails are the same also from 67-79.
First_Ford
I have read that a NEW replacement windshield is thinner so if I pull one from pull a part where can I get a new window seal for the old thick windshield?
Dustin
1968 F-100
fordman
Post by fordman »
its the same gasket they sell now as back then. it has to fit the old windshields too. i doubt that the new winshields are thinner. i guess they could be. but they onlymake one size gasket. it fits all.
