How do I remove broken pins for camper special emblem
I need to remove a broken camper special emblem What is the best way to remove the remaining piece of the emblem and get the pins that have been broken off out of the side panel?
- jor
re: How do I remove broken pins for camper special emblem
You can probably just pop the pin out from the back by pushing on it. You can reach right up there quite easily. The fitting might come with it but if not you can probably push it out as well or grab it from the outside with a pair of bird bills. Here's a photo of the fitting attached to the "Camper Special" trim and a photo of the fitting in the truck. Good luck.
jor
jor
