Hi, i have a question I have yet to answer myself.
i have a 71 f100 4x2 . it started doing something wierd about 2 weeks ago.
what it does, when you come to a stop , set for a few seconds(stop light ) when you release the brakes and accelerate, it starts to pull to the left. at about 45 mph it will jerk back straight.
what i thought at first was left shoes sticking. so i went through the brake system, new everything except drums, they're fine.it still does it. just not as bad.
now i have noticed it does when you accelerate whether you use the brakes or not. i cant find anything on the suspension that looks like it is moving. it has all new bushing in the front. so i dont think that is the problem.the only thing on the brakes i hve not cleaned or replaced is the porportioning valve.
any idea?
'71 pulls on acceleration
Re: '71 pulls on acceleration
king pins? check the rag joint between the column and steering box.
- ezernut9mm
brake hoses new? radius arm bushings?
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
- willowbilly3
I would be looking at the rear leaf springs. It sounds like a broken center bolt, maybe a bad bushing or something along those lines.
i replaced all the bushings inthe front end last spring, the king pins are in good shape,replaced all the brake hoses, wheel cylinders etc. it really felt like a brake sticking. replaced the steering rag about 3 weeks ago.
the rear springs i looked at today while replaceing the rear brake hose, and they dont show any movement that i can find, but a broken spring pin might be it.i had not thought of that yet. i have been rebuilding this truck for the last 2 years. the only thing underneath i have left are the front springs , shocks etc. it sags on the left,but the rear sets good.
- fomocoguy
You say it pulls to the left; have you put on weight over the holidays???
Joe
1971 F100 flareside 8ft
1964 Chrysler New Yorker Town and Country wagon
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- kentdaryl
I had a front brake hose go bad on me, it actually leaked between the inner hose and outer shielding. I couldn't tell any different when I stopped, but the fluid acted like a tourniqet, pinching the hose. After driving a few miles the pressure in the hose would bleed off enough to allow the caliper to relax.
PS - The hose looked just fine from the outside.
that is what i thought at first. i have replaced all the brake hoses except the right front. i just replaced all the wheel cyclinders , shoes, all hoses except right front. this last week. didnt replace the drums , but they are in good shape and dont think that would cause it.
oh and to answer the other dudes question about gaining weight. MOre than likely, but i doubt it has much to do with this either or the truck saging on the left side. LOL
