cleaning out the cowl
customcamper
Post by customcamper »
Any one have any good ideas on how to clean out the cowl just below the windshield??? My son and I are restoring a 1970 f250 cs and have the interior stripped out. I noticed the fresh air inlet at the bottom of the passanger side floor board goes up into the cowl. The cowl has about 3 inches of pine needles and moss inside. I do not want that inside once its done. Can any one help??? Thanks....Dave
Ranchero50
Re: cleaning out the cowl
Post by Ranchero50 »
Use an old antenna to poke up into the drain ports below where the heater openings are. Shop vac works great as well.
Jamie
Brett6269
Post by Brett6269 »
:yt:
lover of old fords
SteveC
Post by SteveC »
i took the two vent pieces out one on each side and used a shop vac to suck all the junk out. and if you pull those vent parts outmight as well replace the rubber seals that keep the water from coming inside
If i confussed you im sorry just tell me and ill try to explain it better
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
fordman
Post by fordman »
pull the vents off of the heater and the drivers side . stick your hand in there and grab the stuff and pull it out. there is a drain at the bottom that is possibly plugged with that stuff. it needs to be clear. if its in the top still just take a garden hose or go to the car wash and spray the stuff down into the bottom and then drag it out by hand.
SteveC
Post by SteveC »
:yt: He explained that very well... looking back at what i typed id swear i was drunk... but no im just really sick and not thinking well lol
1967 f-100 4x4
rjewkes
Post by rjewkes »
aren't there also two of those rubber body plugs on the outside of the cowl that go up into that area? i noticed them when i changed the core support out on my first truck, and again when i wanted to see if a power antenna was possable on our old trucks without cutting sheet metal up.
fuelly.com
Ranchero50
Yeah, they are there, but you need to employ child labor to get anything out through those small holes.
Jamie
flyboy2610
Post by flyboy2610 »
The large oval plug in the middle of the engine compartment firewall is a good place to remove the stuff that hasn't yet fallen down inside the truck.
Red Green
you'd better be right.
OldRedFord
Post by OldRedFord »
fordman wrote:pull the vents off of the heater and the drivers side . stick your hand in there and grab the stuff and pull it out. there is a drain at the bottom that is possibly plugged with that stuff. it needs to be clear. if its in the top still just take a garden hose or go to the car wash and spray the stuff down into the bottom and then drag it out by hand.
Are you talking about the heater vents in the kick panels?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
fordman
Post by fordman »
yes the passenger sid eis the heater ducting that goesss into the kick panel and the other side is the fresh air vent behind the parking brake.
peanutman
Post by peanutman »
I did mine a little different. Remove the plug under the hood in middle of cowl. Cover ext cowl ribs w/ heavy rubber mat material.
Stick heavy duty vac in plug hole and tape around it to secure it in. By closing all that you create somewhat of a suction.
Take a air hose at 120psi and blow up from vent openings. Took about an hour but i got it good and clean. Wash all out with water hose on low flow to check that drain holes are clear and no gaskets leaks. :2cents:
peanutman
Post by peanutman »
These stopped up cowl vents seem to be common. I'm no good at fabracating but it would be nice if a man could get some kind of snap on screen that would fit over vent cowl, look good and keep large leaves, pine needles ect.. out. :hmm:
Jamie are you out there! :pray:
